VIDEO AUX in on Pajero 2008 w/ MMCS
Old Sep 26, 2013 | 03:16 AM
  #31
Doublecheese's Avatar
Hi
It's really been a long time since I did not do anything to my MMCS and I really forgot everything I knew by then . It will take me some time to remember everything but I just don't have that time at the moment.
I am sorry I can not help
Old Sep 26, 2013 | 03:01 PM
  #32
Lillejon's Avatar
Ok anyone else here so have any idea where this cable goes? Can i cut them and connect my phono-cable on this?
Old Oct 2, 2013 | 06:23 AM
  #33
Lillejon's Avatar
Do you have a diagram for this socket in rear? I find it in my car but am not sur what this cable is?
Old Jan 5, 2014 | 12:44 PM
  #34
Lillejon's Avatar
Where goes the d-206 nr 54?
In my car this cable is black and it has been cutted off. I have problems to connect a parrot handsfree, this is a second hand car so the old owner has done something behind the head unit. I cant see where this cable should go? Somewhere else behind this head-unit?
Old Jan 29, 2014 | 02:55 PM
  #35
Benckj's Avatar
Just joined up on forum so busy catching up on all the info. Especially interested in MMCS mods and getting mine to work in English would be a great step. Look forward to some coorespondance.
Jim
Old Aug 20, 2014 | 03:56 AM
  #36
Lillejon's Avatar
I just got mine to work,i had to connect pin-47 to pin-65 to start the aux-button, men i just put the cable in the hole on the connector, anyone know where i van find a pin that i can mount in this connector? I just wait for the cable to fall out, thx
Old Aug 28, 2016 | 04:53 AM
  #37
stevo..'s Avatar
Hello HJB,
Thx again for your help an patience!!!
I renamed some songs and the hdd keeps them memorized i think that it must have to do with this always on wire you mentioned! I notized that if i turn the key to the first ignition step where the dash gets powered up and the mmcs starts up and then i turn the key to the 2 step for the ignition to start the engine the mmcs looses power and restarts again is that normal? If i remember prior to this problem it didnt do that so i think the always on isnt working. Is there a fuse that is on the always on wire?
Old Mar 7, 2018 | 06:45 PM
  #38
Anushka Devruwan's Avatar
Default Aux socket
[QUOTE=greeneagle;229007]OK, I finally got it to work. However, I had to add a bridge and send the
I have montero 2008 exeed. Theres an Aux cable input in the mmcs system. But theres no option in menu to select aux
Old Mar 8, 2018 | 01:40 PM
  #39
HJB's Avatar
HJB
[QUOTE=Anushka Devruwan;323269]
Wow - I havent logged in here for a while....
You are not talking about the 3.5mm jack on the edge of screen when you open it, are you?
As that is for the licence upgrade key.
Old Nov 19, 2019 | 11:48 PM
  #40
aanbae's Avatar
Can it still be for now?
