Where`s the oil going?
Old Nov 12, 2008 | 09:21 PM
hogbygardd's Avatar
Default Where`s the oil going?
95 LS , 150k and no issues with vehicle, regular oil changes and services. Now starting to notice oil loss at a rate of a qt per 4-5 tanks of gas. More if running hard up hill freeway all day. No noticeable mileage change, no smoke, no leaks at all ( not one oil drop !). Vehicle runs great and occasional " check engine" light for a few seconds every 2nd week or so, mech checked it and came up throttle body malfunction, mech not worried about it. Where is my oil going?
Old Nov 12, 2008 | 09:37 PM
dsm1990gsx's Avatar
Default RE: Where`s the oil going?
Check your coolant.
Old Nov 13, 2008 | 04:30 AM
Skiddy's Avatar
I have experienced the same problem with my '00 Pajero. It's time to replace your PCV valve.
Old Nov 13, 2008 | 05:12 AM
4g54's Avatar
valve seal maybe?
Old Nov 13, 2008 | 11:39 AM
dsm1990gsx's Avatar
ORIGINAL: 4g54
valve seal maybe?
That would make it smoke.
Old Nov 13, 2008 | 11:43 PM
4g54's Avatar
where i'm staying valve seal problem does not always produce smoke.
only engine oil will be reducing
Old Nov 20, 2008 | 04:11 PM
hogbygardd's Avatar
Coolant fresh and no oil contamination, Going to try the PCV and see what happens
Old Nov 20, 2008 | 06:28 PM
Manybrews's Avatar
its quite normal for any engine to consume oil.
Just because you cant see it doesnt mean its not entering the combustion chamber. A quart every 4-5 tankfuls is actually acceptable on a brand new car.
And it so happens that the 3.0 liter in your montero uses a LOT of oil as the mileage accrues.
Old Nov 21, 2008 | 12:42 AM
hogbygardd's Avatar
So you are saying that it`s acceptable to consume a oil change worth of oil for every 16 tanks of fuel?
Old Nov 21, 2008 | 04:43 AM
Skiddy's Avatar
Hogbygardd, I think one of the easiest ways to check if you're burning the oil is to see if there's an dark yellow-ish residue left on the right hand side your rear bumper (by the exhaust). It's easy to clean off with some Simple Green, but back when I had bad valve seals, the right side of my bumper was all coated in that stuff. Change your PCV valve and let us know what happens.
