Will Monty operate without floor console, instrument cluster or stereo?
Old Mar 4, 2018 | 05:59 PM
rcan1015's Avatar
Default Will Monty operate without floor console, instrument cluster or stereo?
I've got a heat related problem in my 2005 Montero. I've found a shop that will work on the heater box and/or replace the front heater core. They agreed to let me partially disassemble the dash--remove the passenger seat, floor console, glove boxes, stereo, disc changer, etc. to save on labor costs. Can I still drive the Montero without those items and without the instrument cluster? I figured I would take it apart over several afternoons (weather permitting) and crank it periodically to see if it still runs. I have to drive it 3 miles to the shop and don't want to take it apart and not be able to drive it. Anybody try this already?
Thanks
Old Mar 5, 2018 | 12:19 AM
In the worst case scenario, you can just plug in the instrument cluster and zip-tie it to the wiring harness
Old Mar 10, 2018 | 05:52 PM
rcan1015's Avatar
I removed all components until I had to lower the steering column--and then I stopped. Turns out the only issue was the Montero was operating on battery power only. Once the instrument cluster was removed, the charging system no longer worked.
crios2307
Feb 16, 2010 12:15 PM
Racr_X
Feb 7, 2009 09:50 PM
Tbone52
Dec 17, 2008 07:35 PM
Heretic16
Apr 28, 2008 12:20 AM
Dusty Eclipse
13
Apr 14, 2007 03:05 AM
