New 3rd gen owner, 2002 Limited SR
Old Mar 10, 2018 | 08:16 PM
ilyas's Avatar
Default New 3rd gen owner, 2002 Limited SR
Hi all, finally got my 64k mile 2002 Montero shipped to my house in Georgia. The car was originally purchased by my wife's grandfather in Puerto Rico, hence the 'SR' name (actually has the SR badges too). As far as I can tell, the only differences from a standard US spec Limited are headlight washers and running boards. It's a big change from my other 2 cars: 2002 Camaro built autox and track car, and a 592whp 1997 Viper GTS.
The car's exterior and interior look great, but it's throwing a few codes: P0300 code (random cylinder misfire), lean bank 1 and lean bank 2. It is very slow, and won't rev past 5k RPM at WOT, so it doesn't shift into whichever gear is next when going WOT. Shifts are crisp at part throttle. Idle is 1200rpm about 80% of the time. Unplugging the IAC does nothing. I could go multiple directions from here, but I wanted to first ask you guys if this is a common issue with these cars. What do you guys think the problem is?
Also, the ABS isn't working and the car isn't going into low gearing...but I want to handle the engine issue first.
When I get these things sorted out, I'm putting on a set of 285/75/16 as the car's first mod.
DriftnROCKER77
Jan 16, 2008 06:24 AM
DriftnROCKER77
Jan 16, 2008 01:20 AM
mitsubishi4life20
Mar 13, 2007 12:36 AM
SCOOT3R
Sep 9, 2006 11:30 AM
tidus10
Dec 19, 2005 03:41 PM
