@ Home Oil Change
Old Nov 8, 2007 | 04:59 PM
tufduck's Avatar
Default @ Home Oil Change
What oil filter you guys recommend? Anyone thinking of Fram? almost every auto parts store carry Fram...
Also, I am at 6000 miles. Should I start using synthectic oil? Which brand name oil is the best?
Old Nov 8, 2007 | 05:27 PM
chowc's Avatar
Default RE: @ Home Oil Change
I've stuck with the Mitsu filter for now given it will definitely fit and function properly. Gone with Mobil 1 for the oil even though it is not as good as it use to be....still better than coventional oil.
Old Nov 8, 2007 | 05:32 PM
Fram is the worst filter in the world.
Old Nov 8, 2007 | 06:28 PM
tufduck's Avatar
Is there any oil filter that I can get for the outtie in auto stores that fits? I'll guess use start using synthectcs.
Old Nov 8, 2007 | 07:31 PM
antlip's Avatar
This has been talked about a couple oftimes already. I use the pureone oil filter from advance auto. Cost about 5 bucks. I also use synethic oil. I have been using it since 2000 miles.
Old Nov 8, 2007 | 08:05 PM
bnilguy's Avatar
The Purolator part number is L14610 (add a P on the front for the Pure One). Found at pretty much all auto stores. WalMart sells a SuperTech filter that's highly rated as well
I went to syn on my first change (about 4500 miles)
Old Nov 8, 2007 | 08:19 PM
dsm1990gsx's Avatar
I either use mobile 1 or mitsubishi filters. Like Sebbasaid fram isn't what u want to use.
Vadimus
Nov 26, 2010 12:13 PM
mysterio2099
Apr 23, 2006 10:52 PM
PooT_Nation
Mar 8, 2006 09:42 PM
dansevo
Sep 4, 2005 06:52 PM
dansevo
Aug 22, 2005 02:50 PM
