'03 outlander Trying to Replace Headlamps
Hi everyone, I am new to this site.
Does anyone have tried replacing the headlight assembly on a 2003 outlander? It seems that I have to remove the front bumper in order to do so. Is there a body repair manual out there showing how to remove the bumper?
Thanks!
Thanks!
Follow the below steps to replace the headlamp on your Mitsubishi Outlander:
1) Turn off the engine and raise the hood. Remove the plastic cover at the rear of the headlamp assembly by rotating it counterclockwise, and pulling it off. This will allow access to the headlight bulb.
2) Twist the bulb socket counterclockwise in order to remove it from the headlamp assembly. Pull the old bulb out of the socket, and use a clean cloth to install the replacement bulb. Do not touch the glass of the new bulb.
3) Place the socket back into the assembly, and twist it clockwise. Reattach the plastic cover, and close the hood.
nvpurk
Feb 18, 2007 12:26 PM
jonny_doce
Dec 19, 2005 02:50 AM
