07 interior lighting
#21
According to the Mitsubishi Manual...The Bulb Specifications.
Remember...Any flashing circuit bulb changed to LEDs will require a load resistor(s).
Low Beam - 9006/HB4
High Beam - 9005/HB3
Fog Light - H11
Parking Light - 2827/W5W/Wedge type
Front/Rear Sidebar - 2827/W5W/Wedge type
Front Turn Signal - 992 (7440A) WY21W
Rear Turn Signal - 992 (7440A) WY21W
License Plate (x2) - 2825/W5W/194/Wedge type
Back Up - 7440
Interior Map Front Lights/2, Passenger Area/1, Cargo Area/1 - 3022/31 mm/Festoon type
Low Beam - 9006/HB4
Fog Light - H11
Back Up - 7440
#22
ORIGINAL: abrcrombe
Update:
Here are the pics. Sorry for the blurriness of the first 2, handheld at night with no flash isn't optimal conditions for taking pics.
First is the license plate light. A 6 LED 194 bulb in bright white. This gives off the look of HID's, so a hint of blue.
![](http://i159.photobucket.com/albums/t132/mitchell_reed/DSC_6386-1.jpg)
Second is the interior lights. I think 6 LEDs in a chip form, 31 mm festoon type bulb in bright white. Hard to really show how it looks on camera, but this is the best I could get. Forget what it looks outside, basically the space in front of the dash is how it looks. Very high class feel also with a hint of blue. It makes it look a lot more expensive, and the mood is a lot better than the whitish-yellow of normal bulbs.
![](http://i159.photobucket.com/albums/t132/mitchell_reed/DSC_6392-2.jpg)
Third is my next purchase, LEDs for when the HIDs are on. Didn't even know those were there until I was checking how bright my highbeams were. Then going to change the amber bulbs in the rear turn signal to LEDs that are clear but flash amber. I found out those are the 7440 bulb, which aren't very common.
![](http://i159.photobucket.com/albums/t132/mitchell_reed/DSC_6393-3.jpg)
Update:
#24
ORIGINAL: meldy12
abrcrombe: did you change to LED the bulb in the headlight when HID is on? what LED did you use for this? thanks.
#25
ORIGINAL: Printerman
Hi meldy12:
I just ordered the 6 Led 31 mm festoon.....Did you have a problem installing the Led's...If so what did you do to Led bulb in the cargo
area to get it to fit.....
Thanks.....
Hi meldy12:
Thanks.....
![EEK!](https://mitsubishiforum.com/forum/images/smilies/eek.gif)
#28
When you did the cargo area did you also change the lights located on the bottom of the second row of seats with LEDs?
IM thinking of doing the interior lights in mine with RED High Density LEDs.
Couple reasons
1: It will match the other lighting in the Dash and on the MCC
2: Using Red LEDs should reduce my vision from getting messed up when im driving at night and the person in the passenger seat turns on the overhead. I can only imagine how bad the bright white LEDs are when this happens.
Any thoughts?
Couple reasons
Any thoughts?
#29
These are the part numbers from sylvania for all exterior bulbs
Detailed Bulb List
2007 MITSUBISHI Outlander
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
High mount stop light
Assembly
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7440
Front sidemarker
2827
Detailed Bulb List
Low beam headlamp
9006
High beam headlamp
9005
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Assembly
License plate
2825
Back up light
7440
Front sidemarker
2827
#30
