07 Outlander tire size Limits
A couple more options: my '08 has the 225/60-18 and my '10 has 245/50-18. My rims are stock 8" wide.
Both sets are Michelin Primacy H-rated. Great tires.
Other good websites are TireTack & 1010Tires.
are you SURE that both sets of wheels are 8" wide?? with 225 width on the '08 i'd be willing to bet that they are only 7" wide. otherwise, why would mitsu use two different size tires on the same size rim?
not to mention that there is a 1" difference in diameter between those two sizes.
Pls. post some pictures, just want to see how they actually look on outlander. Thanks.
I asked Elisha the same request. Thanks.
are you SURE that both sets of wheels are 8" wide?? with 225 width on the '08 i'd be willing to bet that they are only 7" wide. otherwise, why would mitsu use two different size tires on the same size rim? not to mention that there is a 1" difference in diameter between those two sizes.
![Confused](https://mitsubishiforum.com/forum/images/smilies/confused.gif)
The 225/60s were the only size in the tire we wanted at the time that would fit and they were cheaper in cost. They are taller than stock.
The 245/50 are 1" wider and by chose for traction. I'm going to try a couple autocross trial runs here.
![Roll Eyes (Sarcastic)](https://mitsubishiforum.com/forum/images/smilies/rolleyes.gif)
[quote=No_Floaters;272042]A couple more options: my '08 has the 225/60-18 and my '10 has 245/50-18. My rims are stock 8" wide.
Any rubbing on the 225/60-18? I'm running into the same problem with the Primacy's, the 225/55/18 are on national backorder and the best they can find are the 60's
my 2010 have 18x8 rims 37mm offset with 235/55 tires. no rubbing issues and still plenty of clearance left. i even think a 245/50 will fit.
my winters are 235/70 on the OEM 16x6.5 rims
i don't think the 2007 and 2010 undercarriage is any different.
