07 xls fogs/DRLs
This is great forum. Have learned alot already. Any way............ I would like for my fog lights to be the DRLs like theXLSs that have HID head lights. Is this a "programming" issue or is there a way to switch the trigger wires for the two lighting systems ?
RE: 07 xls fogs/DRLs
Couple of issues:
1) You need to have the ETACS-ECU reprogrammed. 2) You need to move the fog light relay to the driving light relay position. Its detailed on the inside cover of the engine compartment fuse/relay box. 3) Change bulbs and put in 27 watt driving lights rather than the 55 watt power wasting foggies. |
thanks rdenis. i will get the programmind done. i will be able to do the rest.
does any one have an idea what a stealership should charge for the programming ? I am located in so.cal. |
So what happened? did you ever get this done?
