07 xls fogs/DRLs
Old Jun 6, 2007 | 11:08 AM
07outty's Avatar
Default 07 xls fogs/DRLs
This is great forum. Have learned alot already. Any way............ I would like for my fog lights to be the DRLs like theXLSs that have HID head lights. Is this a "programming" issue or is there a way to switch the trigger wires for the two lighting systems ?
Old Jun 8, 2007 | 12:51 AM
rdenis's Avatar
Default RE: 07 xls fogs/DRLs
Couple of issues:
1) You need to have the ETACS-ECU reprogrammed.
2) You need to move the fog light relay to the driving light relay position. Its detailed on the inside cover of the engine compartment fuse/relay box.
3) Change bulbs and put in 27 watt driving lights rather than the 55 watt power wasting foggies.
Old Jun 8, 2007 | 02:37 PM
07outty's Avatar
thanks rdenis. i will get the programmind done. i will be able to do the rest.
does any one have an idea what a stealership should charge for the programming ? I am located in so.cal.
Old Jun 27, 2010 | 12:19 AM
FiReBReTHa's Avatar
So what happened? did you ever get this done?
Vadimus
Feb 4, 2013 05:26 PM
Pardy
Sep 24, 2009 11:54 PM
mlevasseur
Feb 5, 2009 06:57 AM
klas
Sep 15, 2007 05:11 PM
clipseT
Nov 7, 2005 03:12 AM
