18 tires
What are the largest tires you can install on the 2008 Mitsubishi Outlander XLS 18 Inch wheels without rubbing.?
on customizing outlander a guy in nz but 255/55/20s on
(Post 289986)
here's a good read.. https://mitsubishiforum.com/forum/mi...-limits-39177/ |
245 won't rub but the stock 18" rims are only 7" wide so it's not recommended to go wider than 235 max.
You can fit 22s but you need low profile tires like this guy.
Real photo gallery with custom alloy wheels on . Whee1s.com - best place to find and buy custom alloy wheels and rims |
Looking for the best option on 18 inch tires
Is it better to have more Width on the tire or Height? Can others share their different tire sizes on their 2007-2009 Outlanders? Any Rubbing issues?
Hmm
Depends on your situation. More width and lower profile tired will give you better traction and handling. The lower the profile the less flex in extreme handling. But the low profile tires have little cushion on bumps let alone pot holes.
Will this rub 235/55-18?
What is the biggest tire you can fit on 18" wheels without rubbing?
| All times are GMT -5. The time now is 08:14 AM. |
