2005 Outlander XLS replacing TPS
Old Sep 27, 2014 | 05:51 PM
BrianB's Avatar
Originally Posted by beefos
I got it from a us ebay seller his website is powerxparts.com. It has fixed my problem, I haven't had a cut out since fitting it. Hope you never need one but just in case...
Hi again,
I have decided to replace this sensor, still having the problem from time to time.
When you replaced your one, was it just take the old one off and replace it, or is there more to it, like lining something up.
Brian
Old Sep 28, 2014 | 05:28 AM
beefos's Avatar
Hi, it was just a simple fit job, no adjustment. It took only 5 minutes. I took the assembly from the body to make it easier to access.
Old Oct 2, 2014 | 08:03 PM
BrianB's Avatar
Hi beefos,
I decicded to replace replaced the sensor, apparently it's called a Pedal Travel Sensor, as you said only a 5 minute job, but I dropped one of the bolts, so it took me 10 minutes Ha! Ha!
I did have to make a small adjustment turning the sensor to slow the RPMs down but that was it.
Thanks again for the feedback.
Where in the UK are you from? I moved to Canada from Portsmouth UK.
Brian
Old Oct 3, 2014 | 01:20 PM
beefos's Avatar
Hi Brian, I must have been lucky with the adjustment but an easy job anyway and lots of money saved on the dealers!
I'm in Swindon so 80 miles or so north of you.
BrianB
Jun 3, 2015 02:56 PM
beefos
Jul 11, 2014 08:28 AM
BrianB
Mar 27, 2014 08:20 PM
BrianB
May 10, 2013 08:13 PM
BrianB
Dec 4, 2007 09:16 PM
