2007 LS, looking for better tires
Old May 2, 2009 | 08:40 PM
OTO27's Avatar
Default 2007 LS, looking for better tires
I managed to get 32k out of my OEM geolanders and I am in need of new tires. I would like to get a bigger sidewall sized tire, I hate the gap in the weel wells, and cant afford new rims. What is the biggest tire size I can fit on the stock 16" without making any mods to the car? Oh and does anyone have any recomendations on tire brand and model? I need all season tires, something thats good on the rain and snow.
Old May 4, 2009 | 06:23 PM
OTO27's Avatar
bump..
Old May 5, 2009 | 08:20 PM
OTO27's Avatar
sorry for bumping this up again, dint wana make a new thread, I think I found what I was looking for. After doing some research I will be going with the Goodyear fortera tripple threads. My question is., the original tire size for the LS is 215/70/16 , would I be able to fit a slightly wider 235/70/16 tire size on the stock rim?
Old May 5, 2009 | 11:51 PM
Tasman's Avatar
i am not an expert put with some serch that i have done 235 is the max you can go on 6.5¨ wheel. You better use 65 wich has the same hight as the 215/70.
Old May 6, 2009 | 08:39 AM
bnilguy's Avatar
I'd drop to the 65 ratio as well. The difference is .6% on the diameter...if you stay with the 70 ratio, you're 3.8%. Check the tire specs to make sure it will work on the rim width
2g0s0r1
Mar 13, 2011 11:39 PM
BEAT
Jan 7, 2008 08:38 AM
dirtracineclispe
Apr 9, 2007 10:37 PM
david76008
Mar 1, 2006 02:35 AM
kiwicom
Aug 17, 2004 06:30 PM
