2007 Mitsubishi Outlander A/C Compressor alernatives
Old Mar 10, 2024 | 01:23 PM
pwrcat4000's Avatar
Default 2007 Mitsubishi Outlander A/C Compressor alernatives
Bearing is noisy on my 2007 Mitsubishi Outlander it has the 4.13in Diameter Pulley on a MSC90CAS type compressor there is a much cheaper 3.75in Diameter pulley equipped MSC90CAS type compressor that it is also available for the 07outie that compressor is about 150 dollars cheaper and way more prevalent than the 4.13 inch one. I can also just get a clutch assembly for the 3.75 inch with out going to alibaba and waiting 3 weeks.
My question to you all is
Has anyone ran the MSC90CA 3.75in Pulley compressor on a 2007 outlander with the v6?
The cost savings is huge on my old girl.
PS A/C works great the bearing is quiet when the compressor is running, but it will eventually fail since the bearing is making noise.
Old Mar 29, 2024 | 02:52 PM
pwrcat4000's Avatar
Default got it working
Well if anyone is reading this post and having a similar issue with their AC compressor pulley bearing I was able to get one from Amazon after removing the original bearing which is was a NACHI 35BG05S7DL bearing that measured 35 mm by 50 mm x 20 mm I replaced it with this one from Amazon UOIENRT Air Conditioning...
Amazon Amazon
It worked great.
Edgardo Garrido
Dec 12, 2017 05:02 PM
centerline
Aug 6, 2016 08:35 AM
djones5
Jul 14, 2014 01:53 PM
HunterD
Mar 14, 2014 08:22 PM
happyharold4
May 2, 2011 10:32 PM
