2007 Outlander front sway bar bushing replacement?
Old Nov 30, 2017 | 09:01 PM
FiReBReTHa's Avatar
Default 2007 Outlander front sway bar bushing replacement?
Was trying to find a part or part number but having a hard time.
Anyone have any suggestions?
Old Nov 30, 2017 | 10:35 PM
ccernst's Avatar
https://www.rockauto.com/en/catalog/mitsubishi,2007,outlander,3.0l+v6,1434917,suspensi on,stabilizer+bar+bushing,7624
get them while they are hot!
Old Nov 30, 2017 | 11:01 PM
FiReBReTHa's Avatar
Bam, Got the last two.
Danke senor!
hope that gets rid of the clunk!
Old Dec 1, 2017 | 12:52 AM
catacami's Avatar
Default Mitsubishi > Outlander> 2007> Suspension> STABILIZER BAR & COMPONENTS
https://www.mitsubishipartssource.co...S/6251215.html
Old Dec 1, 2017 | 10:50 PM
ccernst's Avatar
Danke senor!
I just had to replace the links. Test that by grabbing the a-pillar from the outside and try to rock it as hard as you can. If you can hear the clunking, get a friend to do it and start feeling around. If you do work on the links, I have a write up on it.
Old Dec 1, 2017 | 11:10 PM
FiReBReTHa's Avatar
Yea, replaced both links with some moogs with grease fittings (nice upgrade).
I had to replace the front springs since they snapped and one of the old links was bad and had to be cut off so I figured might as well do both. ...But then a clunk manifested and I am guessing sway hopefully since its hitting under my feet when I test drove her car.
Only downside to fixing it is wifey no longer gets me as chauffeur.
Old Dec 2, 2017 | 06:59 AM
ccernst's Avatar
check out lower control arms/lower ball joint too. the rear-most bushing failed and the arm was making contact with the crossmember. Replaced with moog, arms....one failed within 30k miles. I don't think anyone makes a good one with grease fittings.
crash3400
Jun 1, 2012 03:17 PM
Swamp Gas
Oct 4, 2009 01:14 PM
lillben07
Sep 26, 2009 05:05 PM
frs_man
Feb 5, 2009 11:34 PM
gforceauto
Mar 5, 2005 12:27 AM
