2007 Outlander SE Aux Cable install
Old Jun 19, 2010 | 08:49 PM
FiReBReTHa's Avatar
Default 2007 Outlander SE Aux Cable install
I had a MZ360224EX Aux cable for a GTS Lancer laying around the house and my wife wanted an Aux in her car.
http://www.outlander-forum.de/phorum...MZ360224EX.pdf
The only difference is that it uses 2x grounding points instead of one and the orange is the same as red connection that you typically find in the standard Aux install kit.
I then used the Orange wire to take place of the Red and then used the same pinout as
http://forums.evolutionm.net/lancer-...mp3-cable.html
the wires are a different color coding on the 2007 outlander SE but I figured that the connections to the headunit would be the same, and they were.
Here is a photo of the Aux installed into my outies plug.
There are other threads that review how to remove the headunit from the center console.
Old Jun 24, 2010 | 04:15 PM
copyboy311's Avatar
And what do you get from this setup? Is it just a cord that plugs into the mp3 player's headphone jack?
Old Jun 25, 2010 | 09:28 AM
FiReBReTHa's Avatar
yup, thats the aux cable, this post is moreso for folks to recognize the different colored wiring but that the pins still line up.
Old Jun 25, 2010 | 04:52 PM
ivanz's Avatar
In general, most electrical components and wiring are shared with the Lancer. This goes down to the exact same pin configuration for the core ones and the ECU.
danshogun
Jun 22, 2024 02:58 AM
mhc1990
Jan 30, 2021 12:00 PM
M.Dhillon
Mar 15, 2013 10:10 PM
wolfie8
Nov 2, 2009 11:14 AM
ktogun
Jan 6, 2006 04:26 AM
