2007 outlander v6 timing belt
Old Jan 3, 2024 | 03:01 PM
Wdobbs's Avatar
Default 2007 outlander v6 timing belt
Power steering belt shredded and went in timing belt cover and caused the belt to jump time. I put it back in time and now the front 3 cylinders have no compression. I'm guessing it bent all the valves, just seeing if that is all possible, before I start to take the heads off.
Old Jan 8, 2024 | 09:35 AM
Moosejuice's Avatar
This happed to my Endeavor due to a bad alternator pulley. It ended up being cheaper to buy a used motor and replace the one with bent valves.
Old Jan 8, 2024 | 10:19 AM
binzd's Avatar
I did a similar thing (mis-timed by two teeth) and bent the front bank exhaust valves. It took me three months of weekends and evenings to carefully get it apart, craft tools to get into tight spots from Amazon tools, and carefully get all that fiddly hydraulic valve lifter mechanics off while still in order, but when it was done my baby was back on the road and feisty as ever
skipperx
Sep 8, 2012 09:57 AM
jaydizel
Jan 27, 2006 11:48 PM
jaydizel
Jan 15, 2006 08:16 PM
jaydizel
Jan 14, 2006 05:59 PM
dadandcoach
Dec 1, 2003 08:53 PM
