2007 Outlander XLS: Interior Cabin Fan Noise
Old Sep 29, 2014 | 10:48 AM
  #21
ccernst's Avatar
Originally Posted by Cali Duck
I'd go back over the installation, verify all the cables are connected properly. If its not coming on at all, its likely not getting any power, either blown fuse or faulty install.
Let us know.
I haven't had time to look at the service manual, but if a resistor pack is present...it could be burned up as well. not sure if we even have one though. I went through one on a Grand Prix years ago.
Old Sep 30, 2014 | 06:20 PM
  #22
Cali Duck's Avatar
I believe there is:
Erratic Blower Motor Operation Due to Failed Resistor and/or Fan Motor : Mitsubishi Outlander Common Heating & Air Conditioning Problems
Part# RU691:
http://www.stockwiseauto.com/product...odel/Outlander
Old Oct 1, 2014 | 08:55 AM
  #23
ccernst's Avatar
Found a diagram online, part #14. Doesn't look like it is too hard to get to.
2007 Mitsubishi Outlander Parts - Mitsubishi Parts | OEM Mitsubishi Parts | Genuine Mitsubishi Parts
Old Oct 3, 2014 | 11:12 AM
  #24
Cali Duck's Avatar
Bit the bullet and ordered a new blower ($50). Will try to post pics of install for others to see how easy of a job it is.
Old Oct 10, 2014 | 08:03 PM
  #25
Cali Duck's Avatar
Thumbs up
Installed the new blower in under 7 minutes. Very easy, I didn't take pics tho...
1) Remove glove box
2) Remove trim under glove box (2 body pins in the front)
3) Detach cable/hose
4) Unscrew three screws (phillips)
Installation is the reverse. Very simple, very easy, don't know how a dealership could charge more than $100 for this fix...
I followed this YouTube clip for a Lancer and it was 99% identical:
Old Nov 20, 2015 | 10:51 AM
  #26
Outlandish007's Avatar
Default Fan motor bearings squealed and seized
1) Remove glove box
2008 Mitsubishi Lancer HVAC Blower Motor Install How To - YouTube
Thanks for the video and instructions. I replaced mine with your info which made it easy. It was obvious the bearings were seized. Sadly it still doesn't work. Fuze and fuze links were replaced. Is there a test for the blower speed resistor?
Old Nov 20, 2015 | 10:59 AM
  #27
I can't seem to open this link. I'm troubleshooting a seized blower fan that I replaced and still doesn't work.
Thanks
Old Nov 20, 2015 | 06:03 PM
  #28
ccernst's Avatar
Thanks
Just google oem mitsubishi parts....should come up with a few links.
Old Nov 20, 2015 | 06:20 PM
  #29
Guyfromhe's Avatar
In Canada on certain models they have a recall on the blower motor as it was manufactured wrong... Mine was making horrible noises randomly in my 2010 and the dealer fixed it for free.
Old Nov 20, 2015 | 06:26 PM
  #30
Cali Duck's Avatar
Agreed, I received a recall notice as well for the blower motor. I would check with your dealership to see if your VIN is eligible or not.
Sadly, I already replaced mine...maybe I should have them replace it again and keep the one I bought as a spare.
