2008 Outlander adding sub/amp w/Rockford factory system
Old Aug 4, 2008 | 05:40 PM
jay0sun's Avatar
Default 2008 Outlander adding sub/amp w/Rockford factory system
If anyone has any info on audio wiring color codes for the Outlander any help would be greatly appreciated.
Old Aug 4, 2008 | 06:38 PM
jay0sun's Avatar
Default RE: 2008 Outlander adding sub/amp w/Rockford factory system
The plan is to hook up to an aftermarket amp via splitting the preamp output wires running from the factory head unit to the factory amplifier under the seat. I have located a (grey) shielded wire from the factory head unit to the factory amp under the seat that I do believe is the preamp output from the headunit. Unfortunately it is very difficult to determine the correct wires to splice into for the subwoofer. Thanks again to anyone who can help...
Old Aug 4, 2008 | 06:58 PM
jay0sun's Avatar
Picture of the said grey shielded wire from the head unit to the factory amp.
Old Aug 4, 2008 | 07:01 PM
jay0sun's Avatar
Does anyone know what color wires to use as sub channel preamp in?
Old Jul 1, 2025 | 12:45 PM
Renatus's Avatar
Hey, did you manage to figure out the wiring? If yes, would you mind sharing??
seandevlin
Jun 11, 2022 03:00 PM
bytemywhat
Sep 23, 2012 10:16 AM
XxGRYPHONxX
Oct 26, 2011 04:01 PM
Paul L
May 11, 2009 04:17 PM
dtinsley
Sep 25, 2007 09:56 PM
