2009 outlander oil change. 5w20 vs 5w30
Old Jan 24, 2019 | 07:26 AM
newoutlanderfan's Avatar
Default 2009 outlander oil change. 5w20 vs 5w30
Hey all
We have a 2009 outlander with 210,000KM on it and live in Nova Scotia. We just had an oil change and for some reason my gf said to put 5w30 in the truck. The 2009 manual calls for 5w20 but I know 0w20 has been put in before as well.
Any issue with 5w30 going in? Temps are pretty cold here
Thanks
Dave
Old Jan 24, 2019 | 05:47 PM
theSaint024's Avatar
I use 0w20 because that's the closest Walmart has for Mobil One. I'm sure some engineer or expert is going to jump on me for this, but it shouldn't matter too much give or take 5 or 10. My understanding is that it just the viscosity levels for different temperatures. I've never heard of an engine breaking due to using an oil rating that varied by 10, but that's only anecdotal. If temps are cold, I believe you should go with lower ratings like 0w20. My two cents from an amateur, non-engineer.
Old Jan 26, 2019 | 12:24 AM
SERPENTOR's Avatar
I recommend going with a full synthetic 5w20
Old Jan 26, 2019 | 09:35 AM
ccernst's Avatar
You dont say what engine you have, so a little ambiguity.
difference between 5w20 and 5w30, the 30 will be thicker when the engine is up to temp. At cold, they'll have similar viscosity. So likely not an issue other than lower mileage. Only other disadvantage, and very minor, the further the two numbers are, the more the oil will shear/degrade at the end of its life/usefulness due to increased amount of additive packs.
in the 3.0l, a 0w20 might be okay as I believe newer 3.0l are specing 0w20....but my manual calls for 5w20, so that's what I'll use. If 0w20 had to be used, would have to he top tier oil.
a great resource on oils is Bob is the oil guy forums. Forum all about fluids for vehicles.
armymen
Dec 1, 2011 08:39 PM
GalaxyGalant
Sep 24, 2011 10:03 PM
VPower
Jun 10, 2010 08:01 AM
Sal
Feb 25, 2007 09:21 PM
Sal
Feb 13, 2007 03:58 PM
