2010 accessories
Old Mar 11, 2010 | 02:39 PM
jsrd's Avatar
I had finished to install my aluminum pad set. Here pics
Size:  4.2 KB Name:  Pedales_2.jpg
Old Mar 11, 2010 | 10:58 PM
ark_royal's Avatar
I installed a razo pad set. It was universal kit but it is amazingly looking good.
jsrd have you installed the sun visor with light bar yet? Where did you wire it to?
Old Mar 12, 2010 | 01:29 AM
jsrd's Avatar
Yes, I am preparing the writing of the installation
Old Mar 12, 2010 | 12:57 PM
Ian's Avatar
Ian
Hi JSRD,
do you made changes to the arm?
is that it's very complicated to do?
Old Mar 12, 2010 | 01:54 PM
jsrd's Avatar
Hi Ian, I don't removed the arm, I drilled one small hole in the center pedal, removed the one black plastic piece from aluminum pad and fitted it with screw to accel pedal; then, I covered the screw head with same black plastic, just is 0k for me
Old Jun 2, 2010 | 11:31 AM
jsrd's Avatar
Default 2010 wiring diagram for Combination Meter
Hi. Someone have 2010 service manual and can share information? I need the wiring diagram for cluster or combination meter with color screen (METER AND GAUGE SECTION) to see if the harness is compatible with 2007 model to do the "update".
Thank's in advance
Old Jun 2, 2010 | 02:49 PM
ivanz's Avatar
That would be a great mod. I don't see why it would be a different connector...they display the exact same information. At first I though the S-AWC system was a requirement for it, but even the Lancer GTS FWD has the colour MFD.
Old Jun 2, 2010 | 11:53 PM
jsrd's Avatar
I agree. I have the part number, price and clusters is available in stock, but I want to be sure that I will not have problems to do the change; for this reason I would obtain the wiring diagrams first or the help of forum member
Old Jun 18, 2010 | 09:35 AM
jsrd's Avatar
Thank's in advance
Someone?
Old Jun 27, 2010 | 11:56 AM
jsrd's Avatar
Meter and gauge diagrams found. . .
