2010 XLS- Sirius satelite
I have a 2010 XLS. In Canada Mitsubishi provided six months of satelite service. I am not able to receive some of the stations. It seems that those stations tagged with 'adult content' are not being received.
When I log online to Sirius no problem I could listen to all stations.
I contacted Sirius and they said the account is setup to receive all.
Dealer has no clue, abd says I should be receiving all.
Does anyone out there have the same experiance? Or is there a way to unblock or reset?
I already followed the procedure in the users manual to make sure all channels are unlocked.
By the way an example is channel 99 Playboy radio.
Thanks
Thanks
The dealer should have enabled it for you (6 month trial). I believe the radio has to be on when the account is set up or you will have to wait for some time before the activation command is sent again. My Sirius tuner doesn't even get 184 when de-activated, it always says "updating..."
I recently bought an 2010 XLS here in Ottawa with the 6 month free Sirius deal and the sales manager told me you don't get all the stations with the free trial..you only get a sample. If you suscribe at the end of your free trial, you will get everything.
Does anyone know where they mounted the Sirius module for the 6 disc "premium" radio? I imagine it's separate from the radio because I don't think Canada gets the option and I doubt MMNA would make completely separate radios. I would like to disconnect and hopefully remove the sirius station selections from my radio display. The new FUSE system is Fantastic IMO and I use the bluetooth audio streaming to stream Pandora and Sprint Radio right from my phone. Playing music on my phone, getting in and turning the key, my music is piped through the stereo. I can even change the song selection from the radio buttons. But those 4 sirius station menus are annoying to thumb past. Is there any way to disable Sirius and remove the selections from the LED screen?
Sirius in available in the US and Canada. As I mentioned before, I have it.
The Sirius module is always behind the glove box to the right...it says Sirius on. This is regardless of which radio/NAV you have.
Is this satellite module inside of the glove box or actually behind it? How do I get behind the glove box, if so?
Any further information would be greatly appreciated.
Thanks,
Alex
Will this method work on my 2010 Eclipse to disable the satellite choices on my LED radio display?
Thanks,
Alex
Thanks,
Alex
With lower glove box fully down Sirius unit is clearly visible. I'm not sure but it seems to be right above the AC filter.
