2011 Outlander Door Speaker Install
Alright, got everything in there and it sounded great for the few minutes of listening I've gotten in so far. I'll know better in the coming days. I've got the HPF/LPF disabled on the amp and have my head unit with the subs at 63Hz and the door speakers at 80Hz. Slight turn of the gain on the 4 channel amp for front and rear, no gain on the subs. The EQ on the HU is set pretty much flat. I think the rear door speakers do a good job at filling in some sound. I don't really "hear" them, but it's definitely a more full sound than if I have them off. The only problem I ran into is that on the front doors, even with the 1" spacer, the 5.25 Polk MMs seem to be a little wide to fit in the door. The are up about 1cm off the spacer as I wasn't able to screw them down any farther than that without bending them. Do you think that will make a difference? They sound great as far as I can tell. If I turn off my subs, I get a decent amount of bass from all 4 speakers. Can't wait to get some more listening time in!
If your speakers need a thicker spacer, just make one from wood like the ones I posted a photo of above. Only takes a few minutes and is better than the back of the speaker pressing against a door - will probably create rattles etc.
Well done!
Hi guys, does anyone know where the front split speaker system crossover is located for a 2014 Outlander? Is there even a crossover? This model has a tweeter and speaker. It's not the Rockford model.
Thank you
Thank you
vader69
Jun 4, 2020 05:22 PM
vader69
Jul 19, 2011 06:49 PM
Nealla30
Mar 15, 2011 08:40 AM
2011, back, door, flip, install, installation, mitchubesi, mitsubishi, montero, outlander, radio, speakers, sport, sports, tweeter
