2011 Outlander fog lamp bulb replacement
Old Apr 6, 2012 | 11:35 PM
rtracing's Avatar
Default 2011 Outlander fog lamp bulb replacement
Hi All,
Does anybody know how to replace the fog lamp buld on a 2011 Outlander? Any link to a manual or video would be helpful.
Thanks.
Old Apr 7, 2012 | 12:05 AM
zuczek's Avatar
Twist the black/silver ring off the fog light, remove the 3 screws underneath holding the fog light to the bumper and change the bulb..
Old Apr 8, 2012 | 04:19 PM
Phatty McPatty's Avatar
Rtfm
Old Nov 8, 2017 | 06:14 PM
You should be able to access both turn signal bulb and the marker light bulb without removing the headlight assembly. It is a tight squeeze past the aircleaner (and in front of the battery on the other side), but doable. If your bulbs turn out to be OK, you might be having an issue with how your aftermarket alarm is wired. Those things cause more headaches than they solve.
Old Nov 27, 2017 | 12:43 AM
catacami's Avatar
Wink How to replace the fog light lamps on 2011 Mitsubishi Outlander
Originally Posted by rtracing
Hi All,
Thanks.
capricorn1
Jul 29, 2011 05:28 AM
ShortyRider
Jan 9, 2011 09:45 PM
bannerman
Oct 28, 2010 02:37 PM
dksnj
Nov 13, 2006 01:05 PM
95SLracer
Feb 5, 2006 10:28 PM
