2011 Outlander Sport dies when at a stop.......HELP
I purchased a 2011 Mitsubishi Outlander Sport in May (2011). It has about 8,000 miles on it. I love this car except the fact that it has stalled 3x's in the last month. I will be at a stop and all of a sudden the engine dies and the SERVICE ENGINE SOON light is on. I put in park and turn the key, engine starts up fine, no warning lights come up and I am fine? I have googled this issue and there is something in the Outlander V6 called idle neutral logic (supposed to save gas) that is causing the exact same thing. I am pretty sure that only the V6 engines have that. Mine is a 4cyl with CVT. Has anybody else had this issue. Any help would be greatly appreciated!
You contribute nothing with that response.
OP, do you have any way of reading which code it's firing? If so let me know. Do you have a scanner of any sort? If not just bring it to the dealership and they can let you know. But you should feel free to ask any questions you wish.
Thank you Darkstar, here is the deal.....
I took it to my lovely dealership and they hooked up to the computer. There was no code and that was the extent of their help! The service guy looked at me like I had 4 heads and said "Uh, never heard of anything like that." The service manager is on vacation.....so that is why I am on here, trying to see if anyone else has had this problem. I found this forum to be extremely helpful when my fuse system had to be reset for my ipod to work.......again the dealer was clueless on this (so thanks for the "stellar" advice milliesdad)
Has anyone else had this issue in an Outlander Sport??? I can't be the only one.
Thanks for any help/suggestions.
that's gotta be a frustrating problem. the only thing I'd suggest is the next time it does this, record the instrument panel with your camera phone (assuming you have some sort of video or camera ability on your phone). That way you can have some sort of data for the service dept. (works well for veterinarian problems as well!)
A funny look and a shoulder shrug is not a resolution to your issue.
If nothing else the dealership should have tested the idle air control valve instead of just acting like you were making the problem up. A weak idle air control motor can cause the stalling and if that's the case, it doesn't always set a code.
Ccernst had a good idea about taking a picture of the instrument panel the next time it happens. I also suggest you call Mitsubishi's North American headquarters (the number is in your owner's manual) and get them involved. Hopefully they can convince the dealership to take your problem seriously.
Thanks..........
I am going to check the air filter to be sure it is closed up right and will also have the dealer check the idle air control motor.......I will keep you posted!
Thanks again for all the responses.
