Hello all, my '15 SE 2.4L AWD recently threw a oxygen sensor code for bank 1 sensor 1.
I got a replacement which has the same 6 wire wideband NTK replacement but I believe the wiring on the connector is not correct, why you say - this cost 30% less than direct replacements. This NTK sensor, while the same connector/body, seems to not have the proper pinout for the heater. Does anyone have wiring diagrams pinouts? I do believe switching a pin or two should get this working but can't find the wiring info any longer.
Additional info: This O2 sensor does work, the car runs great, gets most mileage I've seen, has power etc etc. However first idle smells bad and it throws the engine light with o2 sensor heater circuit code.
