4 pin connector for fuse - wiring for towbar
Old Jun 10, 2013 | 08:27 AM
milliesdad's Avatar
Originally Posted by senttrox
It's an aftermarket kit and you are right the connector hasn't been supplied with the kit.
I tried to found the separate wire with connector and had no luck.
Do you mean Mitsubishi parts room in the forum?
A Mitsubishi parts person can be you best friend (or your wost enemy). Be nice, tell him/her what you are doing and they might be able to find it. A trip to the Pepsi machine will work wonders.
This type of connector is common for Mitsu's-not just the trailer wiring). You might find a similar connextor in a Pick and Pull salvage yard.
Old May 30, 2024 | 10:29 PM
skiline750's Avatar
Old thread but i can't find any 4 pin plug any color in the left between the headlight and battery. There's only a 6 pin grey plug which isn't a blank. I'm abit over it after spending $ on a proper loom with ECU. Can i supply 12v to the red wire on the white 12 pin connector in the RR corner to power the ECU loom? Failing that i'm going to cut into the wires. I only need to power small LED lights. Cheers.
Old May 31, 2024 | 07:34 PM
DibbyDibbyDJ's Avatar
What year is your outlander?
Old Jun 4, 2024 | 06:18 AM
skiline750's Avatar
It's a 2018 ASX XLS 2.2 diesel. Up here in Qld
Old Jun 4, 2024 | 06:19 AM
skiline750's Avatar
It's a 2018 ASX XLS 2.2 diesel up here in Qld.
Old Jun 5, 2024 | 06:22 PM
skiline750's Avatar
Hi, it's a 2018 asx xls 2.2 diesel.
Old Jun 6, 2024 | 03:03 AM
It is under the left front headlight, taped up to the harnesses there. It is troublesome to get to, but it is there i promise
Old Jun 6, 2024 | 10:45 PM
skiline750's Avatar
Oh it's UNDER? First i've heard that. All other info states between the headlight and battery which is FALSE!
Dibby you are a legend. The grey plug's UNDER the headlight as claimed
Old Jun 7, 2024 | 04:50 AM
Nice one :-)
Old Oct 27, 2024 | 04:54 AM
Mitsy2011's Avatar
Default Wiring for towbar ASX2011
[QUOTE=skiline750;338919]Oh it's UNDER? First i've heard that. All other info states between the headlight and battery which is FALSE!
Dibby you are a legend. The grey plug's UNDER the headlight as claimed.
So you have to run a cable and plug from the front left headlight to the rear?
bradz
Jun 26, 2018 11:30 AM
ricky_racer
Mar 2, 2013 01:36 PM
VR Trooper
Apr 12, 2012 01:25 PM
CaptnKebec
Jul 23, 2010 09:23 PM
yuvex107
Jan 31, 2008 12:25 PM
