710 W Rockford Fosgate how long before drain battery ?
Old Jul 20, 2012 | 06:24 PM
armymen's Avatar
Default 710 W Rockford Fosgate how long before drain battery ?
Hi
i was wondering,
I use my sound system a lots when i go to party and when we have fire outside the house.
i have the 2011 Outlander XLS with the 710 W 710 W Rockford Fosgate sound system.
I know every 30 min, when the car is on Accessory, the power stop, so i have to turn the key off then back to accessory.
But my question is, how long i can do that before the battery drain ?
I usually start my car for 5-10 Min every hours, is that necessarily ?
Let me know what you guy think
thanks
Old Jul 21, 2012 | 12:52 AM
OutlanderGT's Avatar
hard to say it probably depends on how high your volume is.. depends on how old your battery is. If you have Nav it's a little computer which would draw more power.
The 30 minute thing can be disabled by the way, maybe there is a good reason it is 30 minutes so it doesn't drain the battery. it might be a good idea to bring spare battery..
On a side note, what I want to know is how to leave the hatch open (I have the hatch gate LED) and fool the door switch it is closed, so I can possibly leave the hatch open while I sleep with the tailgate flipped down. I will probably get attacked by bears or something so maybe battery is least of my worries
Old Jul 21, 2012 | 10:09 PM
armymen's Avatar
How do you disable the 30 min?
For the door use a bungy cable should do the trick
Old Jul 21, 2012 | 10:10 PM
it you have the nav system it's called ACC cut off or something like that.
Otherwise the dealer can do it.
Old Jul 21, 2012 | 10:11 PM
armymen's Avatar
No Nav
Old Jul 21, 2012 | 10:19 PM
Go to the dealer just pretend you don't know why it shuts down every 30 minutes and your friend's outtie doesn't, they should be able to turn it off for no charge.
seandevlin
Jun 11, 2022 03:00 PM
yuvex107
Jan 5, 2008 11:20 AM
chili_g
Aug 13, 2007 02:05 AM
cllamont
4th Generation
Oct 11, 2005 01:34 AM
Prophet
Jan 15, 2005 12:55 AM
