Accessory outlet
Old Feb 5, 2009 | 07:00 PM
beetlenut's Avatar
Default Accessory outlet
Hello,
First post here. I searched the forums with no luck. I have an 03 Outlander with an accessory outlet or lighter outlet that no longer works. The outlet itself may be toast, but the power wire to the outlet is dead. The lighter fuse behind the coin door, drivers left, is not blown. Is there any other place to look for a fuse or a source of power for this wire? I've read of others with this problem with no solution. Any ideas? Thanks in advance for any help.
Bill
Old Feb 7, 2009 | 02:02 PM
beetlenut's Avatar
Default RE: Accessory outlet
Never mind! Found it. There are two fuses. One in the cabin fuse block, behind the coin compartment, for the cigarette lighter, and another in the engine compartment fuse block, for the accessory socket.
Old Feb 7, 2009 | 08:35 PM
BrodyGuy's Avatar
so im assuming that was the issue? one was blown?
Old Feb 8, 2009 | 11:28 AM
beetlenut's Avatar
Yep, the 15 amp fuse in the engine compartment fuse block #25 - Accessory socket was blown. Has happened several times. The socket is bad. Thinking of just swapping out the socket in the rear of the car because I never use that anyway.
Old Feb 9, 2010 | 10:30 PM
cmurtha's Avatar
beetlenut: I want to give you a huge thanks. I just had this same issue happen and had no idea that fuse in the engine compartment was to the accessory socket. I checked the wiring, the fuse under the driver side and they were good. I was at a loss. I was inches away from having to take it in when voila. I saw your post and checked fuse block#25 in the engine compartment. Problem solved. I'm so pumped up.
Old Jan 14, 2013 | 02:10 AM
catacami's Avatar
Thanks beetlenut, It's good to know! I have 2005 Outlander
Old Aug 27, 2020 | 01:06 AM
Man Dy's Avatar
Default Can you show me where exact the fuse in engine fuse block. I have same problem
Old Aug 27, 2020 | 09:23 AM
Outlander 2.2 DiD 2007-2009's Avatar
Default EGR in Outlander 2.2 DiD model 2007-2009
Where is that AGR? need to clean the valve (P0401), but difficult to locate....
osushinobu
Jul 26, 2007 12:53 AM
chuck_et
Jun 19, 2007 08:37 PM
zbarrett13
Dec 31, 2006 03:30 PM
Talonstorm
Oct 1, 2006 09:19 PM
vpadams
Jul 1, 2004 09:24 AM
