Add aftermarket amplifier to stock audio head unit?
Is it possible to add an additional amplifier to the stock audio head unit in the outlander. My dinky 140 watt stock head unit doesn't do it for me. I thought that modern amplifiers require RCA inputs. Does the stock head unit on the Outlander have RCA outputs that I can connect to an aftermarket amp? I do realize that I will want to upgrade the speakers because the cheap stock speaker may blow out. However, I do not want to replace the Head Unit if I don't have to.
Originally Posted by mchang40
(Post 258382)
ive tried it before and itll work...the deal breaker would be how pleased you are with the results (how itll sound) you have a few options: 1. get a a line output converter (LOC). thiss will connect directly to you speaker wires and provide you rca female plugs at the end. the prices of these are at extreme ends from a few bucks to several hundreds. makers include scosche, peripheral electronics to as high end as jl audio, rf, audison etc 2. OR, there are a few amps, new and old school brands, that will accept high level inputs (speaker wires) directly here's a good site: http://www.installer.com/ http://www.installer.com/hilo/index.php hope thgis helps |
RE:
Thanks Goldenboy.
There is a problem though. When I went to the site, I went to the Mitsubishi section, it had some $99 LOC device but, in the description, it said it was for Crysler. Seems complicated. I think I'll just replace the head unit at Best Buy. I had a bad experience with a Pioneer head unit 2 years ago. The RCA outputs were bad and caused alternator Whine. I had it under warranty and took it back to Circuit City. They didn't even fix it. I fixed it by wrapping a wire around the inputs to ground the connection. But anyway.... I'm thinking either Alpine or Sony. I want something with a touch screen (double DIN) Any suggestions? Thanks! |
i think that's the best way to go instead of using a LOC...cleaner sound, more options, better outcome
i say this coz i used a LOC at first ...I used Audiocontrol EQX paired with 2 Alpine 4ch V12 amps and the sound deteriorated when i started playing at higher volumes and I ended up channging to an AVIC Z2, which I am very happy with with regards to your choices, if it were I...I'd get an Alpine prob a W200 and the like then pair it a a PDX 5 for a compact install (but thats just me) btw, when choosing your 2din dash kit...i maintain that scosche came up with the more formidable kit |
Re:
That sounds good. Unfortunately Best Buy doesn't carry the W200. They will be getting a W900. I think it's very stupid of BB not to mention that the W900 is Bluetooth ready. I found out from other web sites that it is Bluetooth capable with an adapter. Although, for $1K, I think it should have the Bluetooth built in.
Don't you? I don't think I'm going to wait around for it. Because the Sony unit is only $277 at Amazon.com and it's available right now! I didn't see that it was Bluetooth capable but I don't care that much about Bluetooth. Although I do think it's suspect to go from $500 to $300. Makes me think it's not really that good. How much do you think BB would charge me to install it? Would they charge by the hour? They should give me a discount on the installation if I buy an Amp from them. |
Great thread, helped answer some questions I had about adding an Alpine unit to replace the standard stereo on my 2010 outlander. But one problem I seem to be having is trying to find a facia that matches the dash on my outie.
The Metra and Scosche MI3015B ones seem to be plain black while my outlander has a chain mail type effect. Does anyone know where I can get one that matches the dash, preferrably in Eurpoe as I live in Ireland. Thanks Peter |
Originally Posted by PD_BARBS
(Post 258484)
The Metra and Scosche MI3015B ones seem to be plain black while my outlander has a chain mail type effect. Does anyone know where I can get one that matches the dash, preferrably in Eurpoe as I live in Ireland. Thanks Peter in addition, its opening is slightly bigger than most, if not all, aftermarket 2din headunits scosche and metra fit aftermarket units perfectly but only come in black. i prefer scosche for its better fit and finish fyi, there's someone selling a 2din dash kit here not so long ago |
(Post 258407)
I'm not the greatest at wiring up audio. I just had the Memphis unit using rca. However, several friends had amps where you could use the speaker wires as inputs. The do make them. http://www.crutchfield.com/g_347050/...r_Level_Inputs |
Originally Posted by ccernst
(Post 258488)
Engine whine is caused by either a bad ground or the input signals are picking up the alternator noise from a power line...
Originally Posted by mda185
(Post 258538)
I am new to this forum but have been doing DIY mobile audio installs on my personal vehicles for over 20 years. There is a well known problem with several Pioneer head units over the past 5 years, where an internal fuse blows causing the ground shields of the RCA outputs to lose their ground connection inside the head unit. This is repairable. I don't know why BB did not fix it. The fuse is a surface mount device soldered to the circuit board and not easy to fix at home. The thing that causes it to blow is connecting or disconnecting the RCA outputs while the head unit and rear amplifier are both powered up. I am pretty sure 2010 Pioneer head units have an improved design that does not suffer this problem.
