Aftermarket transmission cooler
Old Nov 14, 2012 | 02:55 AM
Gen-8's Avatar
Default Aftermarket transmission cooler
As per title.
Has anyone installed 1 yet? I'm thinking of doing this with summer coming etc... Maby with a temp valve at only opens when it's upto running temperature tho..
Old Nov 14, 2012 | 08:07 AM
ccernst's Avatar
Does the OEM one not work well enough?
Old Nov 14, 2012 | 01:07 PM
Gen-8's Avatar
Summer gets hot.. Towing will increase the temp fast and we have hills galore here so I don't want to weaken the transmission.. I'd say its cooler is built into the radiator like most
Old Nov 14, 2012 | 01:38 PM
ccernst's Avatar
you don't have the small radiator that is in front of the driver's side (here in the states) wheel? I remember a thread a while back where you said your '05 G-spec is like our '07+ generation.
Old Nov 14, 2012 | 07:01 PM
milliesdad's Avatar
Don't even bother with a temp valve. Run it in conjunction with the oe cooler, or get a larger size and block off the oe cooler.
I would run one with the oe cooler, but that's just me.
Out from the oe cooler, in to the external and out to the transmission.
Old Nov 14, 2012 | 08:35 PM
Burtonrider10022's Avatar
It's definitely on my list of things to do... especially for the CVT.
Old Nov 16, 2012 | 11:16 AM
Gen-8's Avatar
Iv had the bumper off and can't see anything so I'm sure I don't have an external one lol
Old Nov 19, 2012 | 02:59 PM
ivanz's Avatar
The external one goes behind the driver side (passenger side in New Zealand) fog light. You can see it clearly (if present) from the air inlet below the fog light.
Old Nov 21, 2012 | 12:34 PM
Gen-8's Avatar
Nope nothing there lol
Old Nov 21, 2012 | 09:48 PM
Vadimus's Avatar
Nothing here...
or here?
If I was worried regarding transmission overheating while towing in the mountains or in slow traffic I'd install a fan in front of transmission radiator.
