Air Con Leak in the vents
I have a 2014 Outlander Diesel. A leak was found in the air con system and the dealer replaced some hoses at full dealer prices. The air con still leaked out after a few days. They then said it was the condenser. I had that work done at a local garage and then had the system tested and recharged. It leaked again after a few days. When charged I can hear a hissing at the centre vents on the dash board. All pipes and seals have been replaced except for anything behind the dash. Before I get the mechanic to remove the dash and look for a leak there can anyone tell me if there is an air con connection point or pipe behind the dash?
I have exactly the same issue. Bought a 2015 outlander and found the A/C didn't work so didn't know the history of the A/C. Got a garage to hook up their machine and they pulled a vacuum successfully for the required amount of time then changed with refrigerant. All seemed ok, drove it for 10 minutes or so and parked up for 5 minutes and when I went back and opened the door was met with a cloud of gas. Could actually see it coming out of the air vents in the dash. Did you find the problem or does anyone have a guide for removing the dash.
