Air conditioner woes
Old May 31, 2007 | 06:17 PM
Default RE: Air conditioner woes
Get a recharge kit and see if that works
Old May 31, 2007 | 07:19 PM
OTO27's Avatar
I would give the freon recharge kit a try, it sounds like it could be just that. You can get them at any autozone, advanced, or NAPA, verry easy and straight forward to hooking it up.
Old May 31, 2007 | 10:45 PM
Big_Bird's Avatar
we took it to a local guy and he recharged the a/c, but it did it again the next day, he couldnt figure the problem
what exactly is freon?can there be a freon leak?
Old Jun 1, 2007 | 10:08 AM
bnilguy's Avatar
They haven't used 'freon' (R-12) for maybe 10 or so years, I don't think you can even buy it anymore (for sure not legally). The repalcement (R-134a) is hard enough to get..you're supposed to have refrigerant recylcing equipment even for that.
I'm starting to think there's a messed up relay,switch, or something electrical. Can scan tools check for this?
Old Jun 1, 2007 | 10:48 AM
CanadianOutlander's Avatar
i have been using my aircon....for a a few days straight and i have had the same problems....it is cold then goes to warm air.....and after a few mintues it goes cold agian....i just had the coolfan thing fix on my vechical as well....it is interesting the same problems people are experiencing are on the 2003......i havent figured out a fix yet...
Old Jun 1, 2007 | 03:57 PM
OTO27's Avatar
Yeah, thanks for clearing that up bnilguy, I meant to just say refrigerant..lol, as you can see I'm not verry fluent with A/C systems, but either way that seems to not be the problem anyways, since yo u already took it to get "recharged".
Old Jun 1, 2007 | 11:43 PM
Big_Bird's Avatar
my uneducated guess is that the fans just cut out. but i dont know why it blinks, the "a/c" flashes instead of staying steady. It did not even work at all today, so i dont evenknow anymore.
Old Jun 1, 2007 | 11:51 PM
Big_Bird's Avatar
Also, just want to thanks you guys for all the help you've been. Way more helpful than other forums I have tried.
Thnx !
Old Jun 2, 2007 | 08:51 AM
hey bigbird....ihave been reading this post.....is swear...my outlander started doing the same thing......i have only owned it for a month now....but now that is summer i have been using the a/c and the same thing as you light was blinking and hot air instead of cool is comming out....keep us posted if you find a fix.....as i am keen to get it patched up on mine.....thanks......
G
Old Jun 2, 2007 | 07:34 PM
BoldlyGoingNowhere's Avatar
If the refrigerant is low it will blink, it knows its low and keeps the compressor from running and makes the light blink so you know to get it looked at.
The 134a is a smaller gas than r12 and has a habit of sneaking out of the system over time. However the most usual place for the AC to get an actual leak is the evaporator inside the dash. This makes it an expensive repair because of the labor involved.
The refrigerant 134a is available at AutoZone orsimilar at least it is here in Cleveland. It can be a do it yourself project provided you can figure out where to connect the adapter and the hose is long enough to allow youto refill your own system. That is if its not so low that it has to actually be tricked into running to get enough refrigerant into the system however if its that low it usually has a leak that needs to be fixed. Its worth a shot the refrigerant isnt that expensive.
