Which Air Filter
Old Feb 21, 2016 | 02:13 AM
SERPENTOR's Avatar
Thumbs up Which Air Filter
Which Car Air Filter do you use and why? Currently using a K&N but beginning to think it's all hype and there are better performing filter brands out there.
Old Feb 21, 2016 | 09:11 AM
The Silent Seed's Avatar
I'd be interested to know what you find out.
Changing the air filter is so rare maintenance-wise, that it's not a cost factor - but anything that will actually improve mpg - I would like to know about.
Old Feb 22, 2016 | 01:46 PM
WHITEOUT2010's Avatar
I use K&N as well. There is not a lot of air filter out there for our cars unless you change out your whole system. There's the AEM Dry Flow but it is just the same as the K&N but a little cheaper. Now, was there a noticeable increase in MPG? Maybe, but nothing noticeable. Was there an increase in HP? Not really. Again, not significant enough to notice. If you want more options for an air filter, upgrade your whole system. I read somewhere in these forums that a Lancer Injen Air Intake bolts right up with no mods. Maybe worth looking into.
Old Feb 22, 2016 | 01:51 PM
Thanks - why would you use the KN filter then? Was it to see if it made a difference, or is there another reason you use them? Do they need to be replaced?
Old Feb 22, 2016 | 10:37 PM
Only because they're a known and reputable brand and I have always used them. It's low maintenance and keeps your throttle body cleaner than other cheap filters. So it seems. Had mine for almost 7 years now since I bought the car brand new in 2009. Replaced it straightaway. You don't need to replace it. Just wash and re-oil with the K&N filter oil.
Old Feb 22, 2016 | 11:48 PM
caskey_b's Avatar
I am using the AEM dry filter.... doesn't need replace like cotton filters.... I bought this one because it is a simple tap the dust/debris out or vacuum out.. (hose out if necessary) but do not need to oil it!
https://mitsubishiforum.com/forum/mi...-filter-48981/
Old Feb 23, 2016 | 07:46 PM
Tlronny's Avatar
http://www.exhausttuningparts.com/pu...?id=154&cid=41
I use the above one which is similar to the AEM one above - works great and flows more than a stock one for sure.
This is for a V6 motor tho
Old Feb 23, 2016 | 10:26 PM
ccernst's Avatar
I've bought Fram and Mann filters. Quick change and I go about my business. When I change it out, I know it is clean and will work properly.
Old Feb 24, 2016 | 08:36 AM
I know I don't want to have to mess with oiling a filter, etc - sounds like a lot of trouble when the stock one I don't even have to think about.
Old Feb 27, 2016 | 04:25 PM
ccernst's Avatar
Bingo....for negligible effect.
