Annoying beeping
Old Dec 16, 2019 | 10:36 AM
PurpleLee's Avatar
Default Annoying beeping
Hi, I'm sure I've seen this posted on here somewhere but can't now find it and in any event no answer was posted so not much help. I have suddenly started getting a beeping noise I've not heard before from the area of the SatNav/Media display area. It is one long and four short beeps. It only seems to occur when starting up and when starting off or travelling very slowly, eg in heavy traffic. No it's not parking or proximity sensors, which sound different, it's not LDW or seat belt warning. I've spoken to a 2 or 3 mechanics, none of whom can tell me what it might be. Before I actually have to take it in to a Mitsubishi dealership (now some way away) can anyone help with what this might be. I know a table of what the various beeps was posted (although again I can't now find it) but it wasn't on there.
Old Dec 16, 2019 | 06:06 PM
albief's Avatar
Could be ice warning beeps depending on where you are
Old Dec 17, 2019 | 02:44 AM
PurpleLee's Avatar
Thanks but no because (a) it wasn't icy yesterday and (b) there is a light comes up on the dash for ice threat. I have now found the previous query about this sequence of beeps on another forum and the suggestion seems to be a loose front parking sensor, although I'm not convinced as I've had that before. Any other ideas please?
Old Dec 17, 2019 | 09:16 AM
AWCAWD's Avatar
I found this thread (with the same symptoms in the PHEV forum. Although it did not offer an obvious solution but it is likely linked to your SAT-NAV unit. Check whether it occurs while approaching a curve ahead and you are traveling faster than advisable. According to my readings one long beep should warn you for this. People, who have navigation unit may verify this or prove me wrong. If this ia the case you are supposed to see a small triangle on the screen. It might be perfectly normal response of the navigation unit or an error in this very same detection mode (approaching a curve too fast).
Eclipse owner
Jun 13, 2016 08:38 PM
topgear
Mar 14, 2009 12:20 PM
ml8853
Aug 27, 2007 10:46 AM
cnipp3173
Jun 12, 2006 04:09 PM
alero440
Oct 18, 2005 05:14 PM
