any good brake pads?
Old May 5, 2009 | 08:53 PM
OTO27's Avatar
Default any good brake pads?
I'm looking at changing my pads soon, anyone have any suggestions as far as some good brake pads go? I was thinking of gettng these: http://www.roadracemotorsports.com/s...products_id=78 but I would like to get confirmation that the outi has the same brakes as the lancers before I buy these.
Old May 6, 2009 | 09:19 AM
bino's Avatar
I'm using akebono ceramic pads on R1 premium slotted/drilled rotors...... so far the combination works ok.......
Old May 6, 2009 | 12:11 PM
RussellM's Avatar
Former Vendor
What year is your outlander? Are you just looking for a good all around pad?
Old May 6, 2009 | 08:05 PM
OTO27's Avatar
I have the 2007 LS AWD. Just looking for a better all round pad.
Old May 7, 2009 | 02:05 AM
Blck3G's Avatar
Akebono are good HAWKS are better.
Old May 7, 2009 | 12:03 PM
alim's Avatar
try EBC brand. They're well made and has practically 0 brake dust. Akebonos are also good but I've found EBC's have a stronger 'bite' when you get on the brakes.
EBC's also have a sandpaper like coating that reduces bed-in time between the pads and rotors. This coating also polishes the rotors--you'll notice how shiny they get as you use them.
Old May 8, 2009 | 01:26 PM
Elisha's Avatar
won't all these hard pads ruin your rotor quicker?
Old May 9, 2009 | 10:46 AM
alim's Avatar
Chances are the oem pads are made of material just as hard if not harder than the aftermarket items you buy.....depending on the brake pad model. Example: the oem toyota pads are much harder than their TRD counterpart and therefore wear out faster. However, they have superior performance to the oem.
Just make sure the pads you purchase exceed oem standards.
Old May 17, 2009 | 12:07 PM
red123's Avatar
where can I find OEM brakes pad for a good price? Also, do I need rear and front pads only? Do I need anything else?
________
Yamaha p-120
07outty
Nov 20, 2007 02:00 PM
Takumi
Nov 1, 2005 04:22 PM
dolfans
May 19, 2004 12:14 AM
Jacoby
Nov 12, 2003 11:14 AM
