Any way to cancel auto-dimming of the MMCS?
I prefer to keep my headlights on at all times while driving. As you probably know, the MMCS auto-dims when the headlights come on. During the day, in sunny Southern California, this results in a display too dim to be seen (especially the nav screen) , even with the brightness turned all the way up. Is there any way to override this, or is the only solution turning off the headlights if I want to use the display during the day?
I know my husband's Prius has a "hidden" control panel that controls many functions that is only displayed if you know the code to activate it; is there anything like that in the MMCS?
Here's the hidden control panel for the Prius- http://www.wikihow.com/Override-Toyo...ation-Gray-out
If you have your option set to "Day" and the brightness all the way up there is nothing else to do. I can't see mine for crap on a sunny day. The Nav unit is just not bright enough.
Double check this though, try turning the lights on and off while your stationary to see if the display dims at all, or undims. That will ensure that the "Day" option is set correctly
bcolins
06-19-2004 01:49 AM
auto, autodimming, brightness, cancelling, diagnostic, dimming, hack, headlight, hidden, menu, mitsubishi, mmc2, mmcs, prevent, prius, screen
