AWC & S-AWC Explaination
I have a couple questions that I can't seem to find the answer to.
1. Is the AWC system in play, even when in 2 wheel drive? (with the front wheels only, obviously.)
2. Based on this thread - could I get a little more clarification on the AWC vs 4wD terminology? On my car's sale-sheet it says AWC, but the car says 2wd / 4wd / Lock. (Also says 4WD on the tailgate.)
3. Also mentioned in this thread is that the "Sport/RVR" has a less sophistaced system than the other trim levels - Huh?
A little confused here - if I'm missing something - apologies.
Thanks in advance for any insight.
For reference: my vehicle is a 2013 Outlander SE.
1. In 2WD mode your ride is FWD. That's it. Rear axle won't be involved no matter what.
2. Mitsu's AWC actually means FWD based drive with rear axle connected through ECC (electronically controlled coupling). In 2WD mode no torque sent to rear wheels, on 4WD Auto the torque is sent on demand, in 4WD Lock the amount of torque sent to rear is maximal.
3. Not really. Outlander Sport/RVR has same AWD system as your Outlander SE. There are 3 drive options possible for non-PHEVs:
- FWD
- AWC (the one you have)
- S-AWC (Outlander GT/XLS)
The latter has Active Front Differential and does not have 2WD mode, it is superior among the all AWD systems on non-PHEV Outlander/Sport/RVR
- FWD
I have a 2015 Outlander SE ( AWC) I drive it in 4WD auto all the time...it handles really well...I like the feeling of the way it tracks..none of that nasty torque steer you get when you really step on the gas in a FWD car.
I wasn't sure I would be even able to do that - does it do any damage in the long term? What about mpg?
I know what you mean by the torque - from time to time, mine will blast forward, pulling - just like an old school turbo.
AFAIK..it won't damage anything..there is no mention in the manual of NOT using 4WD auto all the time...only that using 4WD Lock on dry pavement will increase noise. I've been driving it like that since the first month I've owned it....I have 59,000 KM on it now. I regularly get around 30 + miles to the gallon mostly highway. Perhaps Vadimus or another member may be able to weigh in.
It doesn't seem to...and the tire wear is good as well..nice and even..I rotate them regularly. I only use the Lock Mode when it's really slippery..and with winter tires..these cars are very stable in the snow.
4WD lock can also run in dry pavement, but is really only meant for deep snow and off road.
Yes, you can run with 4wd auto all the time, it only transfers 15% to the rear wheels at start, but can transfer more as necessary if you're in the snow or rain. However, i would probably change the rear diff fluid more often due to the wet clutch being used all the time.
