Best Engine Air Filter and Cabin Air Filter
Old Feb 5, 2018 | 02:51 AM
SERPENTOR's Avatar
Old Feb 5, 2018 | 09:41 AM
frankc98376's Avatar
We have the engine air filters replaced at the dealer when getting oil changed. We found Fram Cabin Air Filters at Walmart.
Old Feb 5, 2018 | 04:26 PM
quietlymknnoise's Avatar
I do not use oiled filters.
Old Feb 5, 2018 | 06:36 PM
Lancerguy2013's Avatar
The Cabin Air Filter is pretty basic to change...I use the Fram ones as well...around 25 CAD here in the GTA. The Engine air filter is a bitch to change...the Mitsu air boxes are well known for the bottom hinges not closing properly after you open them....It's a design I'm not fond of...my 09 Lancer 2.0 litre was wayyyy easier than the current 2.4 litre design..might just be me tho...So I let the Dealer change it once a year...thats about 40,000 KM for me...I drive a fair bit.
Old Feb 5, 2018 | 11:26 PM
Truwarrior22's Avatar
Personally i would use Mitsubishi filters for everything. The Purolator ONE cabin filter I used worked, but the quality was lacking. You have to be careful with the intake oil filters. I guess you can over oil them and cause issues with the intake system components. Last time I was at the dealer a tech was selling a throttle body service due to issues caused by the oiled filter.
Old Feb 8, 2018 | 05:53 PM
ccernst's Avatar
I've used Mahle filters...they work well. check out rockauto.com for most parts...also look at retailmenot.com and search for rockauto....there is a 5% off that usually takes care of shipping...ish.
Old Feb 12, 2018 | 01:25 PM
theSaint024's Avatar
The best filters are the ones you change most often. Cabin air filter isn't really mission critical for the car, so it's just preference. Whatever smells the most pleasant? Air filter is a little different, but I check my air filter regularly and it always looks fine. I will replace at regular scheduled intervals, but there's only so much a different brand of filter can do. The "permanent" air filters do last longer because they can be cleaned, but I'd rather use a disposable filter than a cleaned permanent one. Personal preference, but as long as you change or clean them regularly, it won't matter a whole lot.
OutlanderGT
Mar 4, 2014 04:55 PM
Tony123
Jan 27, 2011 07:50 AM
chis51hd
May 19, 2007 01:42 PM
AWDrivin
Mar 19, 2007 07:42 PM
Biggles
Jul 30, 2006 07:50 PM
