Big Suspension Job
Old Sep 3, 2018 | 09:11 PM
SERPENTOR's Avatar
Default Big Suspension Job
Need to get all the Shocks/Struts Replaced both front and rear, as well as all inner and outer tie rods, how much is a reasonable price for parts and labor for this type of job? It's for a 2008 Mitsubishi Outlander XLS V6
Old Sep 4, 2018 | 08:22 PM
Wheeldog's Avatar
Sorry, all I can help you with is one tie rod end. I had the left outer one replaced on my 08 XLS V6 in 2015 at around 106,000 miles. Cost was $59.32 for the part and $47.63 for labor (not counting the alignment afterward).
I ran across this site when I did a quick search, which says between $280 and $450 for the strut replacement. It is the first time I saw it so no idea of accuracy. RepairPal for Outlander strut replacement
Old Sep 5, 2018 | 09:35 AM
copyboy311's Avatar
I recently paid about $800 to get front struts, rear shocks, alignment and rear brakes/rotors replaced. But the work was done by a mechanic friend I know who works on the side for much lower than shop prices. I asked Firestone for an estimate on shocks and struts alone and it was well over $1000.
Old Sep 5, 2018 | 09:17 PM
ccernst's Avatar
Just priced out new struts, shocks, and misc pieces for about 230 after rebate. Figure 100 bucks per hour. 1 hour per corner. Plus an alignment. I can easily see 1000 bucks at a retail shop. Another 200 for both tie rod ends.
Old Sep 6, 2018 | 01:25 AM
SERPENTOR's Avatar
Default Rockauto
I was looking at Rockauto.com and found this front end kit https://www.rockauto.com/en/catalog/mitsubishi,2008,outlander,3.0l+v6,1442157,suspensi on,front+end+kit,15413
How much labor should it costs to get these installed? I was thinking of buying this Front end kit having Pepboys install then, go to Firestone for the front and rear shock/Struts.
Old Sep 6, 2018 | 10:51 AM
SERPENTOR's Avatar
Default Reuse old Springs
Is it normal when a shop changes a strut for them to reuse the original spring? Do the original springs ever go bad? Which Struts are better Monroe or KYB?
Old Sep 6, 2018 | 10:13 PM
ccernst's Avatar
yeah, springs can go bad, but usually dont. Normal to reuse them. Kyb are oem, which are the ones I'll be going with.
Old Sep 7, 2018 | 09:48 AM
copyboy311's Avatar
But the front springs on these Outlanders especially do go bad. They had a recall on them for rusting and breaking, but if yours aren't rusty I would imagine they're OK. It was particularly a problem in road salt states.
Old Sep 7, 2018 | 11:56 AM
rastel69's Avatar
Difference between OEM struts and KYB aftermarket?
The oem have about the triple price from aftermarket
Old Sep 7, 2018 | 06:54 PM
SERPENTOR's Avatar
I went ahead and did the job at Firestone I had the lifetime alignment, Tire balance/Rotation Lifetime too. They installed new KYB Shocks and Struts front and rear, New inner and outer tie rods. She is riding like a dream now
Gstfat
Apr 30, 2008 10:32 PM
burnmyeyes
Dec 14, 2006 12:08 AM
WIECLIPSEGUY
Mar 19, 2006 04:35 AM
Eclipsel3oy99
Jan 9, 2005 09:01 PM
jakeharris
Apr 16, 2004 05:05 PM
