brake bleed sequence confusion
Old Mar 11, 2020 | 06:02 PM
inandout's Avatar
Question 2012 outie brake fluid bleed sequence confusion
Can somebody explain to me why the manual recommends bleeding in this order?
Is the diagram showing a right side driver setup, and those two things are the MC/booster and ABS unit?
TIA
rich
Old Mar 13, 2020 | 07:32 PM
inandout's Avatar
SOLVED!
I asked a Mitsubishi mechanic and here's his answer:"Most are start at rear and then do the fronts as the abs unit or if no abs, the proportioning valve is set up where the fronts are fed by one port and the rears by another.
But several are set up on a diagonal where the left rear and right front are fed by one port and the right rear and left front by another port.
The theory behind this is that if the brakes should lock up, you wont have the front or rear go into a skid due to both front or both rear wheels locking up as the pressure is going diagonally you will have one front and one rear never locking up which gives you a bit more control.
So you bleed in the order given otherwise you will have air in the system due to how the ports feed the brakes at the wheels. "
Hope this helps others as well = )
Old Apr 23, 2020 | 08:04 AM
Truwarrior22's Avatar
Originally Posted by inandout
SOLVED!
Thanks, I’ll need to do a brake job soon!
user 408320824
Dec 4, 2018 05:41 PM
Mitsawa
Jan 3, 2017 08:39 AM
7-UP BILL
Nov 10, 2010 07:25 PM
Silvertooth
Nov 6, 2006 01:05 AM
