Brake Maintenance
Old Sep 30, 2010 | 04:14 PM
pilcan's Avatar
Default Brake Maintenance
At 24k km, is it necessary to have a brake inspection and brake works be done for the Outie? It's been one winter passed since I bought my Outie and haven't done any cleaning and check ups on my brakes. Any input is appreciated. Thanks.
Old Oct 1, 2010 | 08:57 AM
ccernst's Avatar
My wife is coming on quick to 59000 miles. We are still on the original pads and rotors. I believe we did flush the brake lines at 45000miles though. Flushing is pretty easy. If I were you, just look it over.
Old Oct 1, 2010 | 10:26 AM
nesser's Avatar
I didn't get my vehicle serviced at the dealer for the 24k km "C service". I asked what the work was in the service package. The only thing that worried me in the severe service schedule was the transmission and transfer case fluid check. I talked to the service manager and he says they don't check that until the 2 year mark if you aren't towing anything.
I pulled the transmission dip stick and dropped some fluid on clean white paper - it's not bright pink but it doesn't smell bad so it should be still good.
In my opinion anything beyond just a normal oil change that doesn't include the transmission or some other fluid flush is just glorified oil changes.
If you have the DIY bug:
As I understand it a brake inspection is checking the hoses and piston for leaks as well as the pad thickness through the peep hole in the caliper. This would be done during a tire rotation at a normal garage.
Brake service should include removing the calipers to lube the slide pins at the least.
I did buy mud guards, a trunk liner, oil filter and an engine air filter from the parts department which added up to about what they wanted for the C Service package.
You have to be comfortable with maintaining your warranty. That's what it comes down to. If you don't know much about cars - just stick to the Mitsubishi schedule. Saving a few hundred dollars is great but in the grand scheme of things much less expensive than a new vehicle.
CN
GTAlander
Oct 11, 2005 10:45 PM
3000gt Newbie
Sep 27, 2005 04:48 AM
Jay
Aug 8, 2005 03:20 PM
CobraClutch
Jul 18, 2005 05:27 AM
saynotovtec
Feb 24, 2005 04:49 PM
