Brake systems
Are you sure about that.
Stock brakes is pretty adequate, I found reviews scored shorter stopping distance than the Rav4 and fading was reported in repeated tests but did not affect stopping distance much.
thats good, but i'd sure like to get some really nice looking calipars and cross drilled slotted rotors to boot!
I was looking around for replacement rotors for my outie and this is basically what i found
2009 Mitsubishi Outlander SE:
5 x 114.3 mm bolt pattern
294 or 302 mm disc diameter
12.6 or 13.15 mm bolt size
8.4 or 24 mm minimum thickness
Not sure about the disc diameter, bolt size and minimum thickness..
I would want the brembo brake adapter to fit brembos big brake kits...
why dont you just take a picture of what exactly you need.. and this weekend I can measure the bolts.. or maybe a third party manufacturer like power stop or EBC can give information on this? what measurements will fit?.. if not.. then take the pictures bc im unsure of what exactly you need...
I was browsing on summit racing site they have good choices on Outlander brake replacement parks, slotted rotors, drilled, EBC green pads.
Not big brake kit but I'll probably be shopping there when it comes time to replace the brakes and rotors.
