Brake systems
Old Jul 19, 2012 | 01:13 PM
OutlanderGT's Avatar
Originally Posted by Gen-8
Ours are merly single pot fronts, can ou believe that!!! But they do stop rather nicely tho.. But bigger is better...and my brembos will look better on the outtie than on the shelf growing dst
I think even 1st gen outlander have 2 piston front caliper.
Are you sure about that.
Stock brakes is pretty adequate, I found reviews scored shorter stopping distance than the Rav4 and fading was reported in repeated tests but did not affect stopping distance much.
Old Jul 19, 2012 | 02:36 PM
xOutlanderFiendx's Avatar
thats good, but i'd sure like to get some really nice looking calipars and cross drilled slotted rotors to boot!
Old Jul 19, 2012 | 03:24 PM
Gen-8's Avatar
How bout people measure and report back to me with rotor size and bolt hole spacings and piston numbers too please
Old Jul 19, 2012 | 03:25 PM
Gen-8's Avatar
I want to make a universal part but for majority not minority if you understand me lol
Old Jul 19, 2012 | 05:25 PM
I was looking around for replacement rotors for my outie and this is basically what i found
2009 Mitsubishi Outlander SE:
5 x 114.3 mm bolt pattern
294 or 302 mm disc diameter
12.6 or 13.15 mm bolt size
8.4 or 24 mm minimum thickness
Not sure about the disc diameter, bolt size and minimum thickness..
I would want the brembo brake adapter to fit brembos big brake kits...
Old Jul 20, 2012 | 12:43 AM
Gen-8's Avatar
What is the big break kit you are talking about? 4 pot, 6 pot? And what is the bolt hole centers where the caliper bolts onto the hub
Old Jul 20, 2012 | 12:54 AM
Gen-8's Avatar
And just so we are understanding correctly, I need the centre to centre measurement of the 2 bolts that hold the brake caliper to the hub wheel, not the brake pad bolts!!
Old Jul 20, 2012 | 12:18 PM
why dont you just take a picture of what exactly you need.. and this weekend I can measure the bolts.. or maybe a third party manufacturer like power stop or EBC can give information on this? what measurements will fit?.. if not.. then take the pictures bc im unsure of what exactly you need...
Old Jul 20, 2012 | 05:09 PM
ruski's Avatar
I replaced OEM pads (the were done at ~50K miles) with Raybestos Professional grade ones. I thought the Raybestos Advanced grade would be an overkill.
Kept the OEM rotors so far.
Old Jul 20, 2012 | 05:15 PM
I was browsing on summit racing site they have good choices on Outlander brake replacement parks, slotted rotors, drilled, EBC green pads.
Not big brake kit but I'll probably be shopping there when it comes time to replace the brakes and rotors.
