Can not unlock by remote
Old Sep 26, 2008 | 01:42 AM
marios's Avatar
Default Can not unlock by remote
The last 3 weeks when I try to unlock my car from the remote when it is parked in my garage, it does not respond. When I start the car and then switch off and try again the remote works. This only happens in my garage. Anyone knows why this might be happening?
Old Sep 26, 2008 | 06:13 AM
Shambala's Avatar
Default RE: Can not unlock by remote
signal interference?
Low battery?
maybe you need a new control remote? (my previous remote system had to be replaced every 3 years, I dunno why...)
Your Outlander has become intelligent and has a mind of it's own... [8D] jk...
Old Sep 26, 2008 | 07:49 AM
marios's Avatar
Must have something to do with signal interference then, since this only happens at my garage only. The remote work fine in all other areas. What kind of signal can this be? I am more worriedabout our healththan the actual remote not working
Old Sep 26, 2008 | 10:42 AM
azjake's Avatar
Do you have a garage door opener that also works by remote?
Old Sep 26, 2008 | 11:56 AM
Shambala's Avatar
Here is a list of electronics that could cause interference:
Garage door openers.
Wireless phone systems in the 2.4 and 5Ghz range.
Microwaves.
High frequency radio or CB systems.
Cell phone towers.
Multimedia cell phones. (3G)
Wireless network routers (usually wireless "N" @ 5Ghz is the culprit).
Household electrical wiring (that is only if correct insulation is not used then you are creating electrical noise).
I could go on but those are the ones you'll find around your house...
Old Sep 26, 2008 | 06:54 PM
bluebastion's Avatar
If you have the FAST Key System, I find that if my key fob is in the same pocket as my Iphone, the doors will not unlock. The key fob has to be in a different pocket than the Iphone because apparently the Iphone will interfere with the weak signals given off by the key fob transmitter.
Old Sep 27, 2008 | 06:52 AM
relly_boy's Avatar
ORIGINAL: Shambala
Here is a list of electronics that could cause intererence:
Microwaves.
Cell phone towers.
household electrical wiring (that is only if correct insulation is not used then you are creating electrical noise).
.... thank for your tips
Old Sep 29, 2008 | 02:58 AM
marios's Avatar
No, I don't have an electric door and no other remote operated device installed.....
swilson317
Feb 26, 2015 09:26 AM
alsaaron
Aug 19, 2014 11:23 PM
Timmy5
Sep 7, 2013 10:49 AM
n5926g
Mar 17, 2007 11:10 AM
endeavor16711
Aug 6, 2006 10:52 PM
