Can't get axle piece back in my car?
Old Mar 3, 2018 | 01:15 PM
dopexile's Avatar
Default Can't get axle piece back in my car?
I have a 2WD drive 2012 Outlander SE 2.4... I have been frusterated trying to get this part in for 2 days. I am trying to replace my CV axle but for the life of me, I cannot get this shaft piece back in my car. It is a shaft that connects the transmission to the CV axle and is about a foot long with male splines on both ends. It is the original that slid out of my transmission, so I know it should fit.
Things I've tried:
  • Hitting it in with a rubber and steel hammer
  • Turning it spline by spline
  • Push as hard as I can
Does anyone know the name of this part or the part number? I am concerned that the splines are damaged. Any advice is appreciated
Attached Thumbnails Can't get axle piece back in my car?-20180303_124601.jpg   Can't get axle piece back in my car?-20180303_124527.jpg
Old Mar 7, 2018 | 12:44 PM
WHITEOUT2010's Avatar
Can you take more pictures. Close up and focused shots of the splines on the axle. Usually just hit it with a rubber mallet should do it.
Old Mar 8, 2018 | 08:36 AM
Old Mar 8, 2018 | 01:15 PM
dopexile's Avatar
Thanks for the reply... I do not have the part currently... I sent it to a mechanic and he is going to look and see if the splines can be filed down and rethreaded. When I get it back I think I am going to give it another try.
I did extensive research on this and Mitsubishi parts warehouse told me the part number is 2761A008. I found out this is a MOPAR part, and I tried to order it from a US Mopar parts dealer, but they told me that it is an "export only" part. I was able to find the part on amayama.com, but if I go that route it will have to be shipped from Japan.
Overall a very frustrating experience
Old Mar 15, 2018 | 09:01 PM
dopexile's Avatar
OK I was able to get everything to work out. I looked all over the internet and that shaft part is impossible to replace. I even looked into ordering it from Japan. It is a MOPAR export part that seems to be discontinued.
Anyway, I took my damaged part to a mechanic. He was able to file and sand down the splines. I used some lubrication and I was able to get it into the transmission.
Lesson learned... Use a soft metal hammer when trying to hammer pieces in and be very careful to make sure the splines are straight for next time.
mattyblast
Apr 12, 2018 02:55 PM
Storm
Mar 25, 2008 03:20 AM
classicol
Nov 23, 2007 06:55 PM
DaClipsa
Mar 30, 2006 11:11 AM
jdmeclipse92
Oct 29, 2004 12:58 AM
