Changing steering wheel
I have a 2010 SE Equippe, UK spec, which comes with a steering wheel without the controls.
I have seen one with the controls on eBay, although it has an activated airbag. Is it possible / easy to swap out the airbag and fascia from my steering wheel with the eBay version and install it on my car.
Thanks
Thanks
Yes, it is quite easy to do if you have the right tools and time.
You can use the info from this EVO X guide which tells you how to disassemble the steering wheel: http://www.evoxforums.com/forums/showthread.php?t=2718
I believe the steering column on the Outlander is pre-wired for all the buttons, so it would be a matter of taking off the steering wheel and putting the audio control module in place.
avalanchemike
02-08-2004 07:18 PM
