Chinese DVD / Radio / GPS Installation
#81
Def a sticky, this is probably the closest choice to OEM Nav that users want...
#82
I see that this unit is now available with a better looking interface, there's one on ebay http://cgi.ebay.co.uk/Mitsubishi-Out...d=p3286.c0.m14 Which has got plenty of pictures of the screen.
And there is no clear answer from the seller to these questions:
1. Which media for mp3-tracks is supported by the unit from the list: DVD, CD, USB-storage, SD-card? 2. Does the unit support ID3-tags? If yes, could you provide some photo of the screen with mp3-track info displayed?
Can anyone clear this up for me?
#83
I know it wont play MP3's recorded onto a DVD. I haven't tried mp3's recorded onto a CD yet. It will play mp3's recorded onto a USB Stick. I used an 8 gig stick and when it was inserted into the USB socket it recognised the stick and scanned and read the drive. On the left side of the screen was a list of all the folders and on the right a list of the tracks in the currently opened folder. As far as I know the unit doesn't display ID3-Tags, but does display the mp3 file name at the top of the screen. It isn't too elegant but does work and will play a track from the same position it stopped at, should you turn the unit off and then on again.
#85
#88
please let me know where did you buy that?
dose it support original Rockford fosgate Audio system?
does the streeing wheel buttons work.
how is the quality of Bluetooth.
please send me the linke to where i can buy that and get more info
Thanks
Mike
Thanks
Mike
#89
i checked the ebay seller for this unit and it say Rockford compatible ,does it really mean that Rockford Amp will be tured on with this unit ?
as you might know , Rockford Amp need a CAN signal from unit to start working and the other GPS unit we have , came with a CAN adapter that just make the Streeing wheel buttons functional. i'm wondering if this is a better unit than what i have .
caus on mine , Rockford Amp Does not work and i was told that i have to buy another CAN adapter called Mito -2000
can be bought from :
http://www.autosoundcentral.com/Metr...r_p/mito02.htm
which i don't know if can fix my problem without adding other problem?
does any have any experience on this?
#90
The seller said it does support RF system but my Outlander doesn't have an RF system.
Yes, the steering wheel button works well.
Bluetooth function is good.
