Clicking noise before starting
Old Sep 29, 2012 | 11:22 PM
n0c7's Avatar
Default Clicking noise before starting
I have a 2008 Outlander XLS. Never stood outside the vehicle before starting it until someone else started it for me the other day. I noticed that when the ignition is turned on just before cranking the vehicle I hear a click click click click noise which almost sounds like the injectors are firing up. It stops after 5 seconds or so. Is this normal?
Old Oct 1, 2012 | 12:12 AM
Gen-8's Avatar
Yup it's normal we'll for the 4g series Mitsi motors, if noticed all the GDI fly by wire TBodies do it,might be some sort of self calibrating or priming system given they run on very high fuel pressure
Old Oct 1, 2012 | 09:20 AM
n0c7's Avatar
Interesting. I know that VW likes to activate the fuel pump when you open the drivers door. Thanks for the info.
Old Oct 1, 2012 | 11:42 AM
ccernst's Avatar
08 XLS would have the 6B31 3.0L. I've never noticed the ticking, but I'd assume fuel system priming.
Only other thing that'd click rapidly would be the starter if the battery was low. If you have the OEM battery, you might want to check the fluid level to make sure you aren't low on water.
Old Oct 1, 2012 | 06:28 PM
n0c7's Avatar
Coworker just bought a brand new RVR and I noticed his does this as well. Crisis avoided.
madmat
May 7, 2022 10:50 PM
firebuck
Feb 14, 2018 08:42 AM
Erick21
Jul 26, 2007 12:28 PM
big_k
Feb 16, 2007 05:06 PM
