Clicking sound? Ha! I have a real brain teaser of a problem...
you could not be more right, but its like ford, my old man has a 06 f350 diesel dully. The other day, he was pulling an empty goosneck, pulled up to a four way, and it died. Took it to ford, they told him it was most likely a bad cam sensor, that they get at least two a week in with that problem. They could just go ahead and do a recall, but apparently that would be too easy
ORIGINAL: blackb13
It's probably this:
GROUP 35 Service Brakes : ABS Pump Noise (Update): 2006-07 Eclipse, 2007 Eclipse Spyder and Outlander : ABS System Conducts a self-check to ensure it is functioning properly the first time the vehicle reaches approx 2.5 mph. During the self check, a "clunking" noise will be heard from the right front of the engine compartment. The noise only occurs the first time the vehicle is driven after the engine is started. It will not reoccur until the engine is restarted. This noise is a normal operation of the ABS System. Do not attempt to repair this condition.
It's probably this:
![Big Grin](https://mitsubishiforum.com/forum/images/smilies/biggrin.gif)
![Smile](https://mitsubishiforum.com/forum/images/smilies/smile.gif)
NOTE: How do you guys drive your Outlanders after the first 300 miles of break-in period? I have heard you should drive it hard, fast acceleration to keep the engine tunned or something... (should I start a new thread about this??)
That is the darned sound.
Anyone else hear this metal "clank" once when they first begin moving the car forward??
BlackB13 has some info on that. Hopefully he will drop a line as to the source of that clank.
Is it really common to hear that "clank" sound when you first start to drive forward?? That is is the first time in my life I have ever heard such sound! And I have had a ton of cars with ABS barkes (5 to be exact). No surprise I am concerned! [&:] How sure are you guys that is teh ABS checking itself? (It is definitely not the ball bearing joints - it doesn't click when I turn and they have been just replaced anyway).
ORIGINAL: Christian1
all cars with ABS do it for a self test to make sure the pump is working.
dont worry about it.
BTW, Manybrews is a MMNA tech, so if he says you're good, then you're good.
